주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Use this guide to replace the side buttons on the Axess TA2513-10WT.
부품
지정된 부품이 없습니다.
  1. Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons. Slide the plastic opening tool gently along the sides. If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  5. Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  6. Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner. Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  7. Unlatch the clear rubber holder from the posts with the tweezers. Unlatch the clear rubber holder from the posts with the tweezers.
    • Unlatch the clear rubber holder from the posts with the tweezers.
  8. With tweezers, pull the rubber holder from the back cover completely. With tweezers, pull the rubber holder from the back cover completely.
    • With tweezers, pull the rubber holder from the back cover completely.
  9. Remove the individual buttons with tweezers. Remove the individual buttons with tweezers. Remove the individual buttons with tweezers.
    • Remove the individual buttons with tweezers.
결론
Lori Scott
회원 가입일: 2015년 03월 24일
101 평판
안내서 1개 작성함
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 회원
BU-SHAVER-S15S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 135
