주요 콘텐츠로 건너뛰기
Axess TA2513-10WT Side Button Replacement
필요한 것
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: 1 단계, 이미지 1/1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: 2 단계, 이미지 1/3 Axess TA2513-10WT Side Button Replacement: 2 단계, 이미지 2/3 Axess TA2513-10WT Side Button Replacement: 2 단계, 이미지 3/3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: 3 단계, 이미지 1/1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: 4 단계, 이미지 1/1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: 5 단계, 이미지 1/2 Axess TA2513-10WT Side Button Replacement, Buttons: 5 단계, 이미지 2/2
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: 6 단계, 이미지 1/2 Axess TA2513-10WT Side Button Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: 7 단계, 이미지 1/2 Axess TA2513-10WT Side Button Replacement: 7 단계, 이미지 2/2
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: 8 단계, 이미지 1/3 Axess TA2513-10WT Side Button Replacement: 8 단계, 이미지 2/3 Axess TA2513-10WT Side Button Replacement: 8 단계, 이미지 3/3
    • Remove the individual buttons with tweezers.
결론
Lori Scott
회원 가입일: 03/24/15
101 평판
안내서 1개 작성함
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 회원
BU-SHAVER-S15S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 231
