주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Axess TA2513-10WT Speaker Replacement
필요한 것
    1. Axess TA2513-10WT Speaker Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
      댓글 쓰기
    2. Axess TA2513-10WT Speaker Replacement: 2 단계, 이미지 3개 중 1개 Axess TA2513-10WT Speaker Replacement: 2 단계, 이미지 3개 중 2개 Axess TA2513-10WT Speaker Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
      • Slide the plastic opening tool gently along the sides.
      • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
      댓글 쓰기
    3. Axess TA2513-10WT Speaker Replacement: 3 단계, 이미지 1개 중 1개
      • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
      댓글 쓰기
    4. Axess TA2513-10WT Speaker Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
      댓글 쓰기
    1. Axess TA2513-10WT Speaker Replacement, Speaker: 5 단계, 이미지 1개 중 1개
      • Remove tape attached to black and red speaker wires.
      댓글 쓰기
    2. Axess TA2513-10WT Speaker Replacement: 6 단계, 이미지 1개 중 1개
      • Identify the four speaker nodes.
      • From left to right the nodes are "SPKP1", "SPKN1", "LN", and "LP"
      댓글 쓰기
    3. Axess TA2513-10WT Speaker Replacement: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Place the soldering tool on the speaker node labeled "SPKP1" and quickly remove the red wire with tweezers.
      댓글 쓰기
    4. Axess TA2513-10WT Speaker Replacement: 8 단계, 이미지 1개 중 1개
      • Place the soldering tool on the speaker node labeled "SPKN1" and quickly remove the black wire with tweezers.
      댓글 쓰기
    5. Axess TA2513-10WT Speaker Replacement: 9 단계, 이미지 1개 중 1개
      • Place the soldering tool on the speaker node labeled "LP" and quickly remove the black wire with the tweezers.
      댓글 쓰기
    6. Axess TA2513-10WT Speaker Replacement: 10 단계, 이미지 1개 중 1개
      • Place the soldering tool on the speaker node labeled "LN" and quickly remove the red wire with tweezers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Steven Kavanagh
회원 가입일: 03/24/15
301 평판
안내서 3개를 작성함
팀
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 회원
BU-SHAVER-S15S6G3
3 회원들
안내서 60개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 100
전체 시간: 864
