소개
The battery in the A701 is located adjacent to the motherboard (the blue L-shaped piece) and has soldered wires. Before continuing, be sure you have all the necessary tools and safety equipment.
A guide to soldering can be found here.
필요한 것
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
거의 끝나갑니다!
결론
