주요 콘텐츠로 건너뛰기
소개
This guide demonstrates how to remove the back panel and open the device for repairs and replacements.
부품
지정된 부품이 없습니다.
  1. Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Pry open back piece with plastic spudger. Remove the back piece of the device.
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Gently pry the battery off of the device with the plastic spudger.
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael
회원 가입일: 2015년 03월 11일
541 평판
안내서 4개 작성하였습니다
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 회원
UCCS-PANKO-S15S2G1
3 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 255
