주요 콘텐츠로 건너뛰기
Azpen A701 Motherboard Replacement
필요한 것
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: 1 단계, 이미지 1/1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: 2 단계, 이미지 1/2 Azpen A701 Motherboard Replacement: 2 단계, 이미지 2/2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: 3 단계, 이미지 1/1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: 4 단계, 이미지 1/1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 Azpen A701 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 Azpen A701 Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: 6 단계, 이미지 1/3 Azpen A701 Motherboard Replacement: 6 단계, 이미지 2/3 Azpen A701 Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: 7 단계, 이미지 1/1
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: 11 단계, 이미지 1/1
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: 12 단계, 이미지 1/1
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
결론
Michael
회원 가입일: 03/11/15
568 평판
안내서 4개 작성하였습니다
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 회원
UCCS-PANKO-S15S2G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 308
