이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The screen assembly is located underneath all of the other parts of the device. To access it, you will have to remove these pieces first. Make sure to keep track of all five screws and any connected parts.
필요한 것
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Disconnect the two larger of the three ZIF cables by prying open the flap with a plastic spudger and gently removing the cable.
다른 한 분이 해당 안내서를 완성하였습니다.
