이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Pry open back piece with plastic spudger.
Remove the back piece of the device.
Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
Disconnect the two larger of the three ZIF cables by prying open the flap with a plastic spudger and gently removing the cable.
Peel off the black tape from the corner of the motherboard (indicated by the blue surface of the device)
Use PH000 Phillips head screw driver to remove the three screws that connect the motherboard to the front panel.
Remove the small orange tape attached with a gray wire from the top corner of the device. This is the antenna.
Use plastic spudger around silver lining within the device to pry the screen off.
다른 한 분이 해당 안내서를 완성하였습니다.
