주요 콘텐츠로 건너뛰기
Azpen A701 Speaker Replacement
필요한 것
  1. Azpen A701 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Wedge plastic spudger in between the back panel and the speaker of the device.
  2. Azpen A701 Speaker Replacement: 2 단계, 이미지 1/2 Azpen A701 Speaker Replacement: 2 단계, 이미지 2/2
    • Gently pry out the speaker from the back panel using the plastic spudger.
  3. Azpen A701 Speaker Replacement: 3 단계, 이미지 1/1
    • Heat solder and apply to the wires where they attach to the motherboard. This will disconnect the wires from the motherboard.
    • The wires should still be attached to the speaker.
  4. Azpen A701 Speaker Replacement: 4 단계, 이미지 1/1
    • Take the speaker and wires that are attached out of the device and insert a new speaker by soldering the wires to the motherboard.
결론
To reassemble your device, snap back piece back on to device and secure both 2cm screws at the bottom.
Grant Harding
회원 가입일: 03/11/15
249 평판
안내서 2개 작성하였습니다
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 회원
UCCS-PANKO-S15S2G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 122
