주요 콘텐츠로 건너뛰기
How to replace the Azpen A720 Wi-Fi Antenna
필요한 것
  1. How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: 1 단계, 이미지 1/2 How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: 1 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. How to replace the Azpen A720 Wi-Fi Antenna: 2 단계, 이미지 1/3 How to replace the Azpen A720 Wi-Fi Antenna: 2 단계, 이미지 2/3 How to replace the Azpen A720 Wi-Fi Antenna: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. How to replace the Azpen A720 Wi-Fi Antenna: 3 단계, 이미지 1/1
    • Remove the rear casing.
  4. How to replace the Azpen A720 Wi-Fi Antenna, Wi-Fi Antenna: 4 단계, 이미지 1/1
    • Locate the gray cord attached to the motherboard and the battery. This is the wifi antenna.
  5. How to replace the Azpen A720 Wi-Fi Antenna: 5 단계, 이미지 1/2 How to replace the Azpen A720 Wi-Fi Antenna: 5 단계, 이미지 2/2
    • Locate the soldering connection between the wifi antenna and the motherboard.
    • Using a soldering iron, melt the soldering connection between the cord and the motherboard and disconnect the cord.
    • The soldering iron gets very hot, be careful not to touch the tip to avoid burns. Click here to learn how to solder.
  6. How to replace the Azpen A720 Wi-Fi Antenna: 6 단계, 이미지 1/2 How to replace the Azpen A720 Wi-Fi Antenna: 6 단계, 이미지 2/2
    • Locate the black sticker connecting the wifi antenna to the battery.
    • Peel the black sticker off of the battery to disconnect the wifi antenna.
    • Remove and replace the defective wire.
결론
Anna
회원 가입일: 03/17/15
353 평판
안내서 3개 작성하였습니다
Michigan Tech, Team 1-3, Lauer Spring 2015 Michigan Tech, Team 1-3, Lauer Spring 2015 회원
MTU-LAUER-S15S1G3
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 1,080
