주요 콘텐츠로 건너뛰기
Azpen A740 Battery Replacement
필요한 것
  1. Azpen A740 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Battery Replacement, Battery: 2 단계, 이미지 1/2 Azpen A740 Battery Replacement, Battery: 2 단계, 이미지 2/2
    • Use the set of plastic opening tools to separate the inner backing from the electronics.
    • Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
  3. Azpen A740 Battery Replacement: 3 단계, 이미지 1/1
    • Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
    • In order to desolder these connections follow the instructions on IFixit's How to Solder and Desolder Connections
  4. Azpen A740 Battery Replacement: 4 단계, 이미지 1/2 Azpen A740 Battery Replacement: 4 단계, 이미지 2/2
    • Remove the black tape that is holding the battery in place.
  5. Azpen A740 Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the case using the blue prying or black spudger.
    • As you remove the battery it may be difficult to remove. Take your time to remove it carefully and try to avoid bending it.
결론
Maile Sinclair
회원 가입일: 01/21/15
228 평판
안내서 2개 작성하였습니다
USF Tampa, Team 4-5, Brown Winter 2015 USF Tampa, Team 4-5, Brown Winter 2015 회원
USFT-BROWN-W15S4G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,589
