주요 콘텐츠로 건너뛰기
Azpen A909 Back Cover Replacement
필요한 것
  1. Azpen A909 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Back Cover Replacement: 2 단계, 이미지 1/1
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Back Cover Replacement: 3 단계, 이미지 1/1
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
결론
Karoly Fodor
회원 가입일: 03/15/15
475 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 3-5, Duarte Spring 2015 UMass Dartmouth, Team 3-5, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 437
