주요 콘텐츠로 건너뛰기
Azpen A909 Front and Rear Facing Camera Assembly Replacement
필요한 것
  1. Azpen A909 Front and Rear Facing Camera Assembly Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
  4. Azpen A909 Front and Rear Facing Camera Assembly Replacement, Front and Rear Facing Camera Assembly: 4 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, gently peel back the black electrical tape to reveal the power strip and the front facing camera, which is marked by the red box in the image.
  5. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull the front facing camera out of its mounting point. Use a spudger if necessary.
  6. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Using the spudger, pry the rear facing camera its power strip off the circuit board. This may require some force, since a strong adhesive is used to mount the camera assembly to that point.
  7. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Lift open the connector flap with the spudger.
  8. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • At this point, all points of the camera assembly should be detached from the device.
    • Lift and remove the power strip/camera assembly from the device with a pair of tweezers.
결론
작성자
3다른 기여자 명과 함께
Jordan
회원 가입일: 03/15/15
381 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-5, Duarte Spring 2015 UMass Dartmouth, Team 3-5, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G5
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 212
