주요 콘텐츠로 건너뛰기
B-Flat Clarinet Key Pad Replacement
필요한 것
  1. B-Flat Clarinet Key Pad Replacement, Key Pad: 1 단계, 이미지 1개 중 1개
    • Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
    • If the pad is missing completely, skip to step 3.
  2. B-Flat Clarinet Key Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the damaged pad by inserting the screwdriver under the pad and peeling it off the key.
  3. B-Flat Clarinet Key Pad Replacement: 3 단계, 이미지 1개 중 1개
    • Squeeze a dot of super glue into the empty key.
    • Take care to not overfill the key or glue will ooze out and potentially bind the key to the instrument.
  4. B-Flat Clarinet Key Pad Replacement: 4 단계, 이미지 1개 중 1개
    • Quickly insert the new pad into the key, taking care not to smear the glue.
  5. B-Flat Clarinet Key Pad Replacement: 5 단계, 이미지 1개 중 1개
    • Using the screwdriver, press the pad down to secure it to the key
    • Hold the pad for 5 seconds to let the glue harden
  6. B-Flat Clarinet Key Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Place a small piece of paper between the key and the instrument to avoid residual glue binding the key to the instrument
    • Let the instrument sit out for a few minutes to let the glue fully dry
결승점
작성자
3다른 기여자 명과 함께
Rachel Strobel
회원 가입일: 10/04/17
101 평판
안내서 1개를 작성함
1가이드 댓글
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
Roberto Ottaviani - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 1,623
