주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
B. Front Panel
필요한 것
  1. B. Front Panel, Front Panel Assembly: 1 단계, 이미지 2개 중 1개 B. Front Panel, Front Panel Assembly: 1 단계, 이미지 2개 중 2개
    • Start by placing the NeoPixel rings into the circles. Make sure the pins are at the top center.
    • Thread the Inner Fan part into the circle.
    • Thread the tip into the Inner Fan.
    댓글 쓰기
  2. B. Front Panel, Front Panel Assembly: 2 단계, 이미지 2개 중 1개 B. Front Panel, Front Panel Assembly: 2 단계, 이미지 2개 중 2개
    • Screw the assembled Circle parts into the Front Face using 12x M3x8 countersunk screws
    댓글 쓰기
  3. B. Front Panel, Front Panel Assembly: 3 단계, 이미지 3개 중 1개 B. Front Panel, Front Panel Assembly: 3 단계, 이미지 3개 중 2개 B. Front Panel, Front Panel Assembly: 3 단계, 이미지 3개 중 3개
    • Glue the letters into the Middle Name Plate
    • Slide in the Middle Name Plate, Left and Right Nets into the Assembled Front Panel
    • Using 2x M3x8 button head screws secure the Middle Name Plate to the Assembled Front Panel.
    댓글 쓰기
  4. B. Front Panel, Front Panel Assembly: 4 단계, 이미지 1개 중 1개
    • Slide in the Left and Right Grill into the Front Panel Assembly
    댓글 쓰기
  5. B. Front Panel, Front Panel Mounting: 5 단계, 이미지 2개 중 1개 B. Front Panel, Front Panel Mounting: 5 단계, 이미지 2개 중 2개
    • The Front Panel mounts to the Frame with 4x M3x8 socket head/button head screws with 4x M3 T-Nuts and 2x M5x10 button head screws with 2 M5 T-Nuts
    • The Left and Right Lower Front Grill mount to the frame of the printer with 4x M3x8 button head screws with 4x M3 T-Nuts
    댓글 쓰기
  6. B. Front Panel, LCD: 6 단계, 이미지 3개 중 1개 B. Front Panel, LCD: 6 단계, 이미지 3개 중 2개 B. Front Panel, LCD: 6 단계, 이미지 3개 중 3개
    • Mount the backplate to the arm with 2x M3x8 button head screws.
    • Mount the ball to the arm with 1x M3x8 socket head screw.
    • I also used a drop of superglue.
    • Insert the PanelDue into the backplate lining up the screw holes. Screw the backplate to the front plate with 4x M3x10 button head screws.
    • Mount the full assembly to the front frame re-enforcement with 2x M5x10 button head screws and 2x M5 T-nuts
    댓글 쓰기
  7. B. Front Panel, Results: 7 단계, 이미지 2개 중 1개 B. Front Panel, Results: 7 단계, 이미지 2개 중 2개
    • Looks pretty cool huh?
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David Husolo
회원 가입일: 06/16/21
9,382 평판
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 32
전체 시간: 1,645
