주요 콘텐츠로 건너뛰기
BELLA TXG-DS14 Heating Plate Replacement
필요한 것
  1. BELLA TXG-DS14 Heating Plate Replacement, Heating Plate: 1 단계, 이미지 1/2 BELLA TXG-DS14 Heating Plate Replacement, Heating Plate: 1 단계, 이미지 2/2
    • Turn the device off and make sure it is cooled down. Then place the device in front of you and take the drawer out by placing a hand on the handle and pull towards you. Make sure the plug is out of the way before starting any of the following steps.
    • Slide the clear lock away from the button and press down on the release button to release the basket from the drawer.
  2. BELLA TXG-DS14 Heating Plate Replacement: 2 단계, 이미지 1/2 BELLA TXG-DS14 Heating Plate Replacement: 2 단계, 이미지 2/2
    • Turn the device onto its side and have the bottom surface face you.
    • Remove the 1.5 mm Phillips #1 screws from the bottom of the device. Rotate the screws counterclockwise with a Phillip's #1 screwdriver.
    • There should be 8 screws removed by the end of this step
    • Make sure to keep the screws in a safe spot
  3. BELLA TXG-DS14 Heating Plate Replacement: 3 단계, 이미지 1/3 BELLA TXG-DS14 Heating Plate Replacement: 3 단계, 이미지 2/3 BELLA TXG-DS14 Heating Plate Replacement: 3 단계, 이미지 3/3
    • Place the unscrewed bottom cover next to the device without damaging the cords by extending them.
    • Unscrew all the 1.2mm Phillip's #1 screw around the silver plate by rotating them counterclockwise with Phillip's #1 screwdriver to take the plate off.
    • There should be 6 screws removed by the end of this device
  4. BELLA TXG-DS14 Heating Plate Replacement: 4 단계, 이미지 1/2 BELLA TXG-DS14 Heating Plate Replacement: 4 단계, 이미지 2/2
    • Locate 8 silver holds that holds the silver plate and black cover together.
    • Use a 0.1mm Flathead screwdriver to bend the 8 silver folds toward the center of the circle to release the silver plate.
    • Be careful to not cut yourself on the sharp edges of the silver folds.
  5. BELLA TXG-DS14 Heating Plate Replacement: 5 단계, 이미지 1/1
    • Remove the silver heating plate and install the new one.
    • Fold the silver edges back into place and put the screws back in. For further reassembly , follow this guide in reverse order.
    • When installing the new silver heating plate, make sure to not over bend the silver edges as they can easily break.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Norma Velarde
회원 가입일: 10/19/18
130 평판
안내서 1개 작성함
UC Davis, Team S7-G6, Lore Fall 2018 UC Davis, Team S7-G6, Lore Fall 2018 회원
UCD-LORE-F18S7G6
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
Bella 1.6 txg-af15a
Basket and Drawers
Reinaldo Figueroa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 43
전체 시간: 1,856
