주요 콘텐츠로 건너뛰기
BEM Mojo 2 Charging Base Battery Replacement
필요한 것
  1. BEM Mojo 2 Charging Base Battery Replacement, Charging Base Battery: 1 단계, 이미지 1/1
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Battery Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Battery Replacement: 3 단계, 이미지 1/2 BEM Mojo 2 Charging Base Battery Replacement: 3 단계, 이미지 2/2
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Battery Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
결론
Rachel Iacoboni
회원 가입일: 01/30/18
618 평판
안내서 5개 작성하였습니다
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 400
