주요 콘텐츠로 건너뛰기
BEM Mojo 2 Speaker Battery Replacement
필요한 것
  1. BEM Mojo 2 Speaker Battery Replacement, Speaker Battery: 1 단계, 이미지 1/1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Battery Replacement: 2 단계, 이미지 1/1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Battery Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Battery Replacement: 4 단계, 이미지 1/1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Battery Replacement: 5 단계, 이미지 1/1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
결론
Rachel Iacoboni
회원 가입일: 01/30/18
618 평판
안내서 5개 작성하였습니다
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 12
전체 시간: 530
