주요 콘텐츠로 건너뛰기
BEM Mojo 2 Speaker Replacement
필요한 것
  1. BEM Mojo 2 Speaker Replacement, Speaker Battery: 1 단계, 이미지 1/1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Replacement: 2 단계, 이미지 1/1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
  6. BEM Mojo 2 Speaker Replacement, Speaker Motherboard: 6 단계, 이미지 1/1
    • Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
  7. BEM Mojo 2 Speaker Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the red/black wires in addition to the blue/white wires using the tweezers.
  8. BEM Mojo 2 Speaker Replacement: 8 단계, 이미지 1/1
    • Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
  9. BEM Mojo 2 Speaker Replacement, Speaker: 9 단계, 이미지 1/1
    • Remove any glue that is left over from previous parts that may be covering the screw holes or the speakers drive.
  10. BEM Mojo 2 Speaker Replacement: 10 단계, 이미지 1/2 BEM Mojo 2 Speaker Replacement: 10 단계, 이미지 2/2
    • Remove the speaker's four 10 mm base screws.
  11. BEM Mojo 2 Speaker Replacement: 11 단계, 이미지 1/2 BEM Mojo 2 Speaker Replacement: 11 단계, 이미지 2/2
    • Pry out the speaker's base using the metal Spuger. Use caution upon this step, it will require the use of force.
    • Remove the wire that will be placed in the speakers driver hole for access to the speaker.
  12. BEM Mojo 2 Speaker Replacement: 12 단계, 이미지 1/2 BEM Mojo 2 Speaker Replacement: 12 단계, 이미지 2/2
    • Remove the speaker's two 10 mm screws that are located in its base then take the driver out of the speaker.
결론
Rachel Iacoboni
회원 가입일: 01/30/18
618 평판
안내서 5개 작성하였습니다
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 17
전체 시간: 362
