주요 콘텐츠로 건너뛰기
BIOS battery replacement by why! W253EU
필요한 것
  1. BIOS battery replacement by why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 1개 BIOS battery replacement by why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 2개 BIOS battery replacement by why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 3개
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. BIOS battery replacement by why! W253EU, Access to RAM and CPU from why! W253EU: 2 단계, 이미지 2개 중 1개 BIOS battery replacement by why! W253EU, Access to RAM and CPU from why! W253EU: 2 단계, 이미지 2개 중 2개
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. BIOS battery replacement by why! W253EU: 3 단계, 이미지 3개 중 1개 BIOS battery replacement by why! W253EU: 3 단계, 이미지 3개 중 2개 BIOS battery replacement by why! W253EU: 3 단계, 이미지 3개 중 3개
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. BIOS battery replacement by why! W253EU: 4 단계, 이미지 1개 중 1개
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
  5. BIOS battery replacement by why! W253EU, BIOS battery: 5 단계, 이미지 1개 중 1개
    • Carefully remove the BIOS battery from its holder.
    • Do not throw away the battery! In Switzerland, the electrical shops are obliged to accept all batteries and accumulators for disposal.
결론
For reassembly, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
Martin Kubica님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
31,564 평판
안내서 264개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 798
