주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BLU Advance 4.0 Screen Replacement
필요한 것
  1. BLU Advance 4.0 Screen Replacement, Removing the back cover: 1 단계, 이미지 2개 중 1개 BLU Advance 4.0 Screen Replacement, Removing the back cover: 1 단계, 이미지 2개 중 2개
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
    댓글 쓰기
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 2 단계, 이미지 3개 중 1개 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 2 단계, 이미지 3개 중 2개 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 2 단계, 이미지 3개 중 3개
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
    댓글 쓰기
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: 3 단계, 이미지 1개 중 1개
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
    댓글 쓰기
  4. BLU Advance 4.0 Screen Replacement, Screen: 4 단계, 이미지 2개 중 1개 BLU Advance 4.0 Screen Replacement, Screen: 4 단계, 이미지 2개 중 2개
    • The screen connector is located near the back camera and charger port.
    • Remove the attached screen by gently tugging the cord that connects it to main frame.
    • Pull gently to avoid damaging the connected cable.
    댓글 쓰기
  5. BLU Advance 4.0 Screen Replacement: 5 단계, 이미지 2개 중 1개 BLU Advance 4.0 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • After screen removal, you should be left with the old screen and a plug-in tab .
    • Leave the motherboard and inner screen in one piece.
    • If the inner screen is cracked, replacing the outer screen is useless.
    댓글 쓰기
  6. BLU Advance 4.0 Screen Replacement, Placing in new screen: 6 단계, 이미지 1개 중 1개
    • Work backwards by carefully sliding in the new screen's plug-in tab into the screen connector.
    • The phone will not have sensitivity if the plug-in tab is damaged.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Jon Sclar
회원 가입일: 11/13/14
292 평판
안내서 3개를 작성함
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 63
전체 시간: 4,346
