주요 콘텐츠로 건너뛰기
BLU Advance 4.0 Screen Replacement
필요한 것
  1. 주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    BLU Advance 4.0 Screen Replacement, Removing the back cover: 1 단계, 이미지 1/2 BLU Advance 4.0 Screen Replacement, Removing the back cover: 1 단계, 이미지 2/2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 2 단계, 이미지 1/3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 2 단계, 이미지 2/3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 2 단계, 이미지 3/3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: 3 단계, 이미지 1/1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
  4. BLU Advance 4.0 Screen Replacement, Screen: 4 단계, 이미지 1/2 BLU Advance 4.0 Screen Replacement, Screen: 4 단계, 이미지 2/2
    • The screen connector is located near the back camera and charger port.
    • Remove the attached screen by gently tugging the cord that connects it to main frame.
    • Pull gently to avoid damaging the connected cable.
  5. BLU Advance 4.0 Screen Replacement: 5 단계, 이미지 1/2 BLU Advance 4.0 Screen Replacement: 5 단계, 이미지 2/2
    • After screen removal, you should be left with the old screen and a plug-in tab .
    • Leave the motherboard and inner screen in one piece.
    • If the inner screen is cracked, replacing the outer screen is useless.
  6. BLU Advance 4.0 Screen Replacement, Placing in new screen: 6 단계, 이미지 1/1
    • Work backwards by carefully sliding in the new screen's plug-in tab into the screen connector.
    • The phone will not have sensitivity if the plug-in tab is damaged.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jon Sclar
회원 가입일: 11/13/14
292 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 3,763
