주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. With the back camera on the top side and facing you, find a notch on the bottom right side of the phone. Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. Remove the battery. Remove 3 screws from each side with a  Phillips 00 screwdriver. Unclip the screen by sliding a flat rigid tool  between the black and the blue side-band.
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jon Sclar
회원 가입일: 2014년 11월 13일
292 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,279
