주요 콘텐츠로 건너뛰기
BLU Dash 3.5 Battery Replacement
필요한 것
  1. BLU Dash 3.5 Battery Replacement, Battery: 1 단계, 이미지 1/3 BLU Dash 3.5 Battery Replacement, Battery: 1 단계, 이미지 2/3 BLU Dash 3.5 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Battery Replacement: 2 단계, 이미지 1/2 BLU Dash 3.5 Battery Replacement: 2 단계, 이미지 2/2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
결론
Aaron Boehm
회원 가입일: 03/01/17
201 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G2, Harley Spring 2017 IUPUI, Team S1-G2, Harley Spring 2017 회원
IUPUI-HARLEY-S17S1G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 249
