주요 콘텐츠로 건너뛰기
BLU Dash 3.5 Camera Replacement
필요한 것
  1. BLU Dash 3.5 Camera Replacement, Battery: 1 단계, 이미지 1/3 BLU Dash 3.5 Camera Replacement, Battery: 1 단계, 이미지 2/3 BLU Dash 3.5 Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Camera Replacement: 2 단계, 이미지 1/2 BLU Dash 3.5 Camera Replacement: 2 단계, 이미지 2/2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Camera Replacement, Camera: 3 단계, 이미지 1/3 BLU Dash 3.5 Camera Replacement, Camera: 3 단계, 이미지 2/3 BLU Dash 3.5 Camera Replacement, Camera: 3 단계, 이미지 3/3
    • Use the J000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Camera Replacement: 4 단계, 이미지 1/2 BLU Dash 3.5 Camera Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Locate camera module on inside of the black plastic back panel
    • Note the orientation of the camera.
    • Use tweezers to carefully remove the camera.
결론
victoria dorony
회원 가입일: 09/28/15
22 평판
안내서 1개 작성함
Ohio State, Team 1-2, Garvin Fall 2015 Ohio State, Team 1-2, Garvin Fall 2015 회원
OSU-GARVIN-F15S1G2
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 350
