주요 콘텐츠로 건너뛰기
BLU Dash JR D140 Digitizer Replacement
필요한 것
  1. BLU Dash JR D140 Digitizer Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Digitizer Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Digitizer Replacement, Digitizer: 3 단계, 이미지 1개 중 1개
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Digitizer Replacement: 4 단계, 이미지 1개 중 1개
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Digitizer Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Digitizer Replacement: 6 단계, 이미지 1개 중 1개
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Digitizer Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Digitizer Replacement: 8 단계, 이미지 1개 중 1개
    • When the ribbon cable is removed from the ZIF connector, peel off the power, sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Digitizer Replacement: 9 단계, 이미지 1개 중 1개
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Digitizer Replacement: 10 단계, 이미지 2개 중 1개 BLU Dash JR D140 Digitizer Replacement: 10 단계, 이미지 2개 중 2개
    • Separate the screen cover from the motherboard using the plastic opening tool. And don't forget that your phone can mess up if u separate the motherboard from the screen cover
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Nathanael
회원 가입일: 07/23/15
233 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 1,312
