주요 콘텐츠로 건너뛰기
BLU Dash JR D140 Microphone Replacement
필요한 것
  1. BLU Dash JR D140 Microphone Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Microphone Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Microphone Replacement, Microphone: 3 단계, 이미지 1/1
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Microphone Replacement: 4 단계, 이미지 1/2 BLU Dash JR D140 Microphone Replacement: 4 단계, 이미지 2/2
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Microphone Replacement: 5 단계, 이미지 1/1
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Microphone Replacement: 6 단계, 이미지 1/1
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Microphone Replacement: 7 단계, 이미지 1/1
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Microphone Replacement: 8 단계, 이미지 1/1
    • When the ribbon cable is removed from the ZIF connector, peel off the power sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Microphone Replacement: 9 단계, 이미지 1/1
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Microphone Replacement: 10 단계, 이미지 1/1
    • Separate the screen cover from the motherboard using the plastic opening tool.
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
  11. BLU Dash JR D140 Microphone Replacement: 11 단계, 이미지 1/3 BLU Dash JR D140 Microphone Replacement: 11 단계, 이미지 2/3 BLU Dash JR D140 Microphone Replacement: 11 단계, 이미지 3/3
    • The microphone is at the bottom left corner of the phone.
    • Lift the microphone very carefully. Unsolder the two lower wires (one red wire and one black wire).
    • If you don't feel comfortable with this step I recommend looking at Ifixit's solder guide here.
    • Solder the new microphone in the same spot. The black wire will go in the left spot and the red wire in the right spot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Saravpreet singh
회원 가입일: 07/08/15
179 평판
안내서 1개 작성함
UW Tacoma, Team 1-4, Liner SU 2015 UW Tacoma, Team 1-4, Liner SU 2015 회원
UWT-LINER-SU15S1G4
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 497
