주요 콘텐츠로 건너뛰기
BLU Dash Music 4.0 Speaker Replacement
필요한 것
  1. BLU Dash Music 4.0 Speaker Replacement, Remove the Back Cover: 1 단계, 이미지 1/1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Speaker Replacement, Remove the Battery: 2 단계, 이미지 1/1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: 3 단계, 이미지 1/2 BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: 3 단계, 이미지 2/2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: 4 단계, 이미지 1/2 BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: 4 단계, 이미지 2/2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the covers apart.
  5. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: 5 단계, 이미지 1/3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: 5 단계, 이미지 2/3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: 5 단계, 이미지 3/3
    • Locate the speaker
    • Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board.
    • Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
  6. BLU Dash Music 4.0 Speaker Replacement, Place the New Speaker: 6 단계, 이미지 1/1
    • Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Place the new speaker onto the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lioma Terrero Soto
회원 가입일: 10/16/14
525 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G8
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 471
