소개
In this guide the user will have to open the back of the phone and remove the top pate to expose the battery connection to the motherboard. Because the battery is not supposed to be removed, there is an adhesive on the back of the battery that makes it difficult to remove from the phone. The metal spudger is the best tool to use to pry the battery from the phone body.
필요한 것
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Hi. I my short Band Aid q makes connection between the battery and cell .. q do ? They are fixable ?
directions were pretty straightforward... mine had a tiny sticker w/ the "B" in BLU printed, covering the screw on the upper left corner that needed removal (warranty?). otherwise, simple replacement...thanks!
