주요 콘텐츠로 건너뛰기
BLU Energy X Motherboard Replacement
필요한 것
  1. BLU Energy X Motherboard Replacement, Battery: 1 단계, 이미지 1/3 BLU Energy X Motherboard Replacement, Battery: 1 단계, 이미지 2/3 BLU Energy X Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Motherboard Replacement: 2 단계, 이미지 1/2 BLU Energy X Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Motherboard Replacement: 3 단계, 이미지 1/3 BLU Energy X Motherboard Replacement: 3 단계, 이미지 2/3 BLU Energy X Motherboard Replacement: 3 단계, 이미지 3/3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
  4. BLU Energy X Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 BLU Energy X Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Use the flat end of a spudger to flip up the black retaining flap on the ZIF connector.
  5. BLU Energy X Motherboard Replacement: 5 단계, 이미지 1/2 BLU Energy X Motherboard Replacement: 5 단계, 이미지 2/2
    • Gently pull the ribbon cable free of the ZIF connector.
  6. BLU Energy X Motherboard Replacement: 6 단계, 이미지 1/2 BLU Energy X Motherboard Replacement: 6 단계, 이미지 2/2
    • Gently peel up the antenna.
    • This is secured with some light adhesive, so some force may be required.
  7. BLU Energy X Motherboard Replacement: 7 단계, 이미지 1/3 BLU Energy X Motherboard Replacement: 7 단계, 이미지 2/3 BLU Energy X Motherboard Replacement: 7 단계, 이미지 3/3
    • Gently rotate the motherboard up so that the front-facing camera is pointed towards you.
    • Use the pointed end of a spudger to disconnect the antenna cable and the ribbon cable.
  8. BLU Energy X Motherboard Replacement: 8 단계, 이미지 1/2 BLU Energy X Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift the motherboard up and out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
90,216 평판
안내서 89개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 427
