소개
The back camera may become damaged or scratched over time, causing poor quality pictures. This guide will explain how to access, remove, and replace your BLU Life X8 back camera.
필요한 것
Flip the phone over so that the screen is facing down.
Slide the opening tool between the micro-USB port and the back cover.
Use the opening tool to create a gap.
Use the Phillips #00 (1.5mm) bit to undo the (9) screws from the back of the device.
다른 한 분이 해당 안내서를 완성하였습니다.
