주요 콘텐츠로 건너뛰기
BLU Life X8 Screen Replacement
필요한 것
  1. BLU Life X8 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 BLU Life X8 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Screen Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 BLU Life X8 Screen Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
  5. BLU Life X8 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
  6. BLU Life X8 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Once all the clips have been released, lift the frame and set it aside.
  7. BLU Life X8 Screen Replacement: 7 단계, 이미지 2개 중 1개 BLU Life X8 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
  8. BLU Life X8 Screen Replacement: 8 단계, 이미지 3개 중 1개 BLU Life X8 Screen Replacement: 8 단계, 이미지 3개 중 2개 BLU Life X8 Screen Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
  9. BLU Life X8 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
  10. BLU Life X8 Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Slowly lift the vibration motor away from the frame and peel up the tape.
  11. BLU Life X8 Screen Replacement, Daughterboard: 11 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
  12. BLU Life X8 Screen Replacement: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the transparent tape covering one of the ribbon connectors using the tweezers.
  13. BLU Life X8 Screen Replacement: 13 단계, 이미지 3개 중 1개 BLU Life X8 Screen Replacement: 13 단계, 이미지 3개 중 2개 BLU Life X8 Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Use the tweezers to lift the black and beige tabs securing the ribbon cables.
    • Pull back on the ribbon cables to release them from their connectors.
  14. BLU Life X8 Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the daughterboard from the frame using the plastic opening tool.
  15. BLU Life X8 Screen Replacement, Screen: 15 단계, 이미지 1개 중 1개
    • Take off the sticker and the ribbon cables glued to the back of the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexander Prasil
회원 가입일: 09/28/17
546 평판
안내서 5개를 작성함
USF Tampa, Team S1-G2, Nance Fall 2017 USF Tampa, Team S1-G2, Nance Fall 2017 회원
USFT-NANCE-F17S1G2
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 551
