소개
Replacing the charging port on your BLU Life XL device is an effective method of attempting repair of charging issue. This guide shows how one may replace the internal lower PCB unit, where the charging port is located.
필요한 것
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
다른 2명이 해당 안내서를 완성하였습니다.
