주요 콘텐츠로 건너뛰기
소개
A faulty motherboard can render your smartphone inoperable. This guide demonstrates the steps required to replace the motherboard on a BLU Life XL smartphone.
  1. Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen. Remove the rear cover using your hands at the lip on the device back cover. No tools required. Remove the battery by lifting the lower edge of the battery up first.
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver. Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. Firmly press the prying tool into the gap between the front glass and rear plate.  This gap is located on all sides of the phone. Run the prying tool around the entire phone separating the rear plate from the frame.
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  5. Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery. Replace the component and reapply the tape over the buttons. Replace the component and reapply the tape over the buttons.
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
  6. Remove the two 12x3mm screws using the Phillips #000 screwdriver. Remove the ribbon cables.
    • Remove the two 12x3mm screws using the Phillips #000 screwdriver.
    • Remove the ribbon cables.
  7. The ribbon cables are attached by zero insertion force (ZIF) connectors.  To disconnect the cable, flip up the small locking flap and pull the cable out. The ribbon cables are attached by zero insertion force (ZIF) connectors.  To disconnect the cable, flip up the small locking flap and pull the cable out. The ribbon cables are attached by zero insertion force (ZIF) connectors.  To disconnect the cable, flip up the small locking flap and pull the cable out.
    • The ribbon cables are attached by zero insertion force (ZIF) connectors. To disconnect the cable, flip up the small locking flap and pull the cable out.
  8. Remove the white ZIF connector then remove the cable connecting the digitizer to the motherboard by gently pulling. An adhesive pad attaches this component to the motherboard. To remove it, use a pair of tweezers to gently pry it upwards. An adhesive pad attaches this component to the motherboard. To remove it, use a pair of tweezers to gently pry it upwards.
    • Remove the white ZIF connector then remove the cable connecting the digitizer to the motherboard by gently pulling.
    • An adhesive pad attaches this component to the motherboard. To remove it, use a pair of tweezers to gently pry it upwards.
  9. The motherboard should now be free from its mount in the phone, but it is still connected to the PBC data cable. To remove the cable from the motherboard, gently pry upward. The motherboard is now free and can be replaced. The motherboard is now free and can be replaced.
    • The motherboard should now be free from its mount in the phone, but it is still connected to the PBC data cable. To remove the cable from the motherboard, gently pry upward.
    • The motherboard is now free and can be replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Hook
회원 가입일: 2019년 03월 25일
199 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G6, Hovde Fall 2019 IUPUI, Team S1-G6, Hovde Fall 2019 회원
IUPUI-HOVDE-F19S1G6
4 회원들
안내서 2개 작성하였습니다
how i identified the components in this motherboard
victor ismael piñero hernandez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 19
전체 시간: 115
