주요 콘텐츠로 건너뛰기
BLU Life XL Volume Control Buttons Replacement
필요한 것
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 1 단계, 이미지 1/3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 1 단계, 이미지 2/3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 1 단계, 이미지 3/3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Volume Control Buttons Replacement: 2 단계, 이미지 1/2 BLU Life XL Volume Control Buttons Replacement: 2 단계, 이미지 2/2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Volume Control Buttons Replacement: 3 단계, 이미지 1/2 BLU Life XL Volume Control Buttons Replacement: 3 단계, 이미지 2/2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Volume Control Buttons Replacement: 4 단계, 이미지 1/3 BLU Life XL Volume Control Buttons Replacement: 4 단계, 이미지 2/3 BLU Life XL Volume Control Buttons Replacement: 4 단계, 이미지 3/3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
결론
James Whitlow
회원 가입일: 02/14/18
342 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G5, Eyestone Spring 2018 USF Tampa, Team S2-G5, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 262
