주요 콘텐츠로 건너뛰기
BLU R2 Plus Fingerprint Sensor Replacement
필요한 것
  1. BLU R2 Plus Fingerprint Sensor Replacement, Power Off: 1 단계, 이미지 1개 중 1개
    • Be sure that your BLU R2 Plus is completely powered off and has less than 25% battery left. This will lower the chance of your battery catching fire and your logic board/motherboard shorting out.
  2. BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: 2 단계, 이미지 3개 중 1개 BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: 2 단계, 이미지 3개 중 2개 BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: 2 단계, 이미지 3개 중 3개
    • Insert your pick in the top left-hand corner where the little indent is.
    • Slide the pick all the way around the phone until the back cover is loose and ready to be released.
  3. BLU R2 Plus Fingerprint Sensor Replacement, Remove Back Cover: 3 단계, 이미지 1개 중 1개
    • Remove the Back Cover to gain access to sim card trays, the memory card slot, or just to replace it.
  4. BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: 4 단계, 이미지 3개 중 1개 BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: 4 단계, 이미지 3개 중 2개 BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening pick to peel up the sticker from the arms of both the upper and lower plastic plates on both sides of the battery. This will reveal screws to both plates.
    • To hold back the sticker, use small bits of tape.
  5. BLU R2 Plus Fingerprint Sensor Replacement, Unscrew Upper Plastic Plate: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to unscrew the nine screws from the upper plastic plate.
  6. BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: 6 단계, 이미지 3개 중 1개 BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: 6 단계, 이미지 3개 중 2개 BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: 6 단계, 이미지 3개 중 3개
    • Using an opening pick to wedge under spaces around the upper plate, unclip the upper plate from the phone and slide it up and out.
  7. BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 7 단계, 이미지 3개 중 1개 BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 7 단계, 이미지 3개 중 2개 BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to carefully pull up the fingerprint sensor from the upper plate.
결론
작성자
2다른 기여자 명과 함께
Derek Thomas
회원 가입일: 09/02/21
778 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 135
