주요 콘텐츠로 건너뛰기
BLU Studio 5.0 II Power Button Replacement
필요한 것
  1. BLU Studio 5.0 II Power Button Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Power Button Replacement: 2 단계, 이미지 1/2 BLU Studio 5.0 II Power Button Replacement: 2 단계, 이미지 2/2
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Power Button Replacement: 3 단계, 이미지 1/3 BLU Studio 5.0 II Power Button Replacement: 3 단계, 이미지 2/3 BLU Studio 5.0 II Power Button Replacement: 3 단계, 이미지 3/3
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Power Button Replacement, Back Case: 4 단계, 이미지 1/1
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Power Button Replacement: 5 단계, 이미지 1/3 BLU Studio 5.0 II Power Button Replacement: 5 단계, 이미지 2/3 BLU Studio 5.0 II Power Button Replacement: 5 단계, 이미지 3/3
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  6. BLU Studio 5.0 II Power Button Replacement, Power Button: 6 단계, 이미지 1/3 BLU Studio 5.0 II Power Button Replacement, Power Button: 6 단계, 이미지 2/3 BLU Studio 5.0 II Power Button Replacement, Power Button: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the power button on the left side of the motherboard.
    • Using a spudger or a pair of tweezers, carefully remove the power button yellow film attached to the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ricardo Sarabia
회원 가입일: 02/09/16
1,069 평판
안내서 6개 작성하였습니다
USF Tampa, Team 7-5, Cheng Spring 2016 USF Tampa, Team 7-5, Cheng Spring 2016 회원
USFT-CHENG-S16S7G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 854
