주요 콘텐츠로 건너뛰기
BLU Studio 5.0 II SIM Card Replacement
  1. BLU Studio 5.0 II SIM Card Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II SIM Card Replacement: 2 단계, 이미지 1/2 BLU Studio 5.0 II SIM Card Replacement: 2 단계, 이미지 2/2
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II SIM Card Replacement: 3 단계, 이미지 1/3 BLU Studio 5.0 II SIM Card Replacement: 3 단계, 이미지 2/3 BLU Studio 5.0 II SIM Card Replacement: 3 단계, 이미지 3/3
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II SIM Card Replacement, SIM Card: 4 단계, 이미지 1/1
    • Locate the SIM Card above the battery.
  5. BLU Studio 5.0 II SIM Card Replacement: 5 단계, 이미지 1/2 BLU Studio 5.0 II SIM Card Replacement: 5 단계, 이미지 2/2
    • Use your finger to apply a small pressure on the SIM Card.
    • Slide your finger downwards in order to remove the SIM Card from the slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ricardo Sarabia
회원 가입일: 02/09/16
1,069 평판
안내서 6개 작성하였습니다
USF Tampa, Team 7-5, Cheng Spring 2016 USF Tampa, Team 7-5, Cheng Spring 2016 회원
USFT-CHENG-S16S7G5
3 회원들
안내서 7개 작성하였습니다
댓글 3개
it seems i have  problem geting the phone working through trac phone they its working but cant call out it blu xtreme 2.5 whats up?
anthony - 답글
my phone wont call out tracphone say its working but no its a BLU xtreme 2.5 any answers?
anthony - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,064
