소개
This guide will show you how to replace the volume button on your Blu Studio 5.0 II phone.
필요한 것
Locate the four 3mm screws on each side of the back panel.
Use a Phillips #00 screwdriver to remove the eight screws.
Locate the volume button on the right side of the phone after removing back case.
Using a spudger carefully wedge between button and phone and carefully pry away from the phone.
Once removed the yellow buttons will be visible.
다른 2명이 해당 안내서를 완성하였습니다.
