주요 콘텐츠로 건너뛰기
BLU Studio 5.0 II Volume Button Replacement
필요한 것
  1. BLU Studio 5.0 II Volume Button Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Volume Button Replacement: 2 단계, 이미지 1/2 BLU Studio 5.0 II Volume Button Replacement: 2 단계, 이미지 2/2
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Volume Button Replacement: 3 단계, 이미지 1/3 BLU Studio 5.0 II Volume Button Replacement: 3 단계, 이미지 2/3 BLU Studio 5.0 II Volume Button Replacement: 3 단계, 이미지 3/3
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Volume Button Replacement, Back Case: 4 단계, 이미지 1/1
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Volume Button Replacement: 5 단계, 이미지 1/3 BLU Studio 5.0 II Volume Button Replacement: 5 단계, 이미지 2/3 BLU Studio 5.0 II Volume Button Replacement: 5 단계, 이미지 3/3
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  6. BLU Studio 5.0 II Volume Button Replacement, Volume Button: 6 단계, 이미지 1/2 BLU Studio 5.0 II Volume Button Replacement, Volume Button: 6 단계, 이미지 2/2
    • Locate the volume button on the right side of the phone after removing back case.
    • Using a spudger carefully wedge between button and phone and carefully pry away from the phone.
    • Once removed the yellow buttons will be visible.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Zack Miliziano
회원 가입일: 02/09/16
146 평판
안내서 1개 작성함
USF Tampa, Team 7-5, Cheng Spring 2016 USF Tampa, Team 7-5, Cheng Spring 2016 회원
USFT-CHENG-S16S7G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 231
