주요 콘텐츠로 건너뛰기
BLU Studio 5.0 S II Camera Replacement
필요한 것
  1. BLU Studio 5.0 S II Camera Replacement, Remove back cover: 1 단계, 이미지 1/1
    • Remove the back cover of phone with the plastic opening tool.
  2. BLU Studio 5.0 S II Camera Replacement, Remove battery: 2 단계, 이미지 1/1
    • Remove the battery with the plastic opening tool.
  3. BLU Studio 5.0 S II Camera Replacement, Remove screws: 3 단계, 이미지 1/1
    • Use the Philips #00 screwdriver to remove the nine screws that the top back part of the phone has.
  4. BLU Studio 5.0 S II Camera Replacement, Remove the plastic backing of phone: 4 단계, 이미지 1/1
    • Once you take off the screws off the phone remove the plastic backing .
  5. BLU Studio 5.0 S II Camera Replacement: 5 단계, 이미지 1/2 BLU Studio 5.0 S II Camera Replacement: 5 단계, 이미지 2/2
    • Remove the ribbon cable carefully on all four sides of the motherboard of the phone.
  6. BLU Studio 5.0 S II Camera Replacement, Remove screws from motherboard: 6 단계, 이미지 1/1
    • Take off the four interior screws that are on the motherboard of the phone.
  7. BLU Studio 5.0 S II Camera Replacement, Remove plastic film: 7 단계, 이미지 1/1
    • Remove the ribbon cable next to the camera carefully.
  8. BLU Studio 5.0 S II Camera Replacement, Remove motherboard: 8 단계, 이미지 1/1
    • Remove the motherboard of the phone and replace camera.
결론
Maria Juzaino
회원 가입일: 10/25/14
499 평판
안내서 3개 작성하였습니다
Gateway, Team 1-3, Johnson Fall 2014 Gateway, Team 1-3, Johnson Fall 2014 회원
GCC-JOHNSON-F14S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,991
