소개
This guide will guide you through the steps required to replace the screen of a BLU Studio 5.0 S II. This guide will require difficulty the same as replacing the motherboard. The prerequisites will be everything for replacing the motherboard.
필요한 것
Remove the back cover of the phone with the plastic opening tool, or your fingers.
Remove the battery from the phone with the plastic opening tool, or your fingers.
Remove the microSD and SIM card. Gently tug on the microSD and SIM card to slide them out of their insert.
To reassemble your device, follow these instructions in reverse order with the screen replacement.
다른 2명이 해당 안내서를 완성하였습니다.
