주요 콘텐츠로 건너뛰기
BLU Studio 7.0 II Back Cover Replacement
필요한 것
  1. BLU Studio 7.0 II Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Locate the seam between the black and silver pieces of the phone.
    • Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
    • To create the initial separation for the plastic opening tool, you may need to use either a spudger or metal spudger. If you use a metal spudger, be aware this can damage your phone if you aren't careful.
  2. BLU Studio 7.0 II Back Cover Replacement: 2 단계, 이미지 1/1
    • Work your way around the edge of phone, firmly prying the pieces apart.
  3. BLU Studio 7.0 II Back Cover Replacement: 3 단계, 이미지 1/2 BLU Studio 7.0 II Back Cover Replacement: 3 단계, 이미지 2/2
    • Once the back has been removed, you can snap the new one into place by pressing firmly around the edges with your fingers.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Abby
회원 가입일: 05/14/16
852 평판
안내서 5개 작성하였습니다
Metro State, Team 1-2, Carpenter SU 2016 Metro State, Team 1-2, Carpenter SU 2016 회원
MSU-CARPENTER-SU16S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 34
전체 시간: 2,106
