소개
This guide provides steps on how to replace the battery of the Blu Studio 7.0 II.
필요한 것
Locate the seam between the black and silver pieces of the phone.
Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
이 단계에 사용된 도구:Tweezers$4.99
Using the PH00 screw driver, remove the two 3mm screws.
Remove the metal clip that connects the battery ribbon to the motherboard by lifting up. Precision tweezers work best for this part.
다른 한 분이 해당 안내서를 완성하였습니다.
