주요 콘텐츠로 건너뛰기
BLU Studio G Antenna Replacement
필요한 것
  1. 주의: 1-8 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    BLU Studio G Antenna Replacement, Motherboard Prerequisite: 1 단계, 이미지 1/3 BLU Studio G Antenna Replacement, Motherboard Prerequisite: 1 단계, 이미지 2/3 BLU Studio G Antenna Replacement, Motherboard Prerequisite: 1 단계, 이미지 3/3
    • To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
    • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
  2. BLU Studio G Antenna Replacement: 2 단계, 이미지 1/2 BLU Studio G Antenna Replacement: 2 단계, 이미지 2/2
    • Locate the notch at the bottom of the battery for safe removal.
    • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
  3. BLU Studio G Antenna Replacement: 3 단계, 이미지 1/2 BLU Studio G Antenna Replacement: 3 단계, 이미지 2/2
    • Unscrew the 13 Phillips #0 screws from the back of the phone.
  4. BLU Studio G Antenna Replacement: 4 단계, 이미지 1/1
    • To remove the back panel, slide the metal spudger into 3 notches on left and right side outside edges of the device.
    • With some slow but strong pressure insert and dislodge the panel from the rest of the device. These are tough but small clips that hold together the back panel.
  5. BLU Studio G Antenna Replacement: 5 단계, 이미지 1/2 BLU Studio G Antenna Replacement: 5 단계, 이미지 2/2
    • Remove all 8 3.175 mm screws that secure the motherboard in place.
    • Remove by turning counter clockwise using a Phillips #0 bit with the correct screwdriver using medium/ firm pressure, assuring that you don't strip the screws.
    • Set aside
  6. BLU Studio G Antenna Replacement: 6 단계, 이미지 1/3 BLU Studio G Antenna Replacement: 6 단계, 이미지 2/3 BLU Studio G Antenna Replacement: 6 단계, 이미지 3/3
    • Locate the two connector clamps on the motherboard.
    • Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
    • Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
  7. BLU Studio G Antenna Replacement: 7 단계, 이미지 1/1
    • Locate the speaker on the bottom of the device and slowly pry upwards and to the right as its wired to the motherboard.
  8. BLU Studio G Antenna Replacement: 8 단계, 이미지 1/3 BLU Studio G Antenna Replacement: 8 단계, 이미지 2/3 BLU Studio G Antenna Replacement: 8 단계, 이미지 3/3
    • Locate the volume button strip on the left side of the device and slowly pry outwards from one end to the other from the device.
    • Carefully pull over the motherboard.
  9. BLU Studio G Antenna Replacement, Antenna: 9 단계, 이미지 1/1
    • The antennae will be soldered directly to the motherboard which will be replaced.
결론
Christian Perez
회원 가입일: 04/11/17
494 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 602
