주요 콘텐츠로 건너뛰기
BLU Studio G Battery Replacement
필요한 것
  1. BLU Studio G Battery Replacement, Battery: 1 단계, 이미지 1/3 BLU Studio G Battery Replacement, Battery: 1 단계, 이미지 2/3 BLU Studio G Battery Replacement, Battery: 1 단계, 이미지 3/3
    • To remove the back cover, locate the safety indented notch on the bottom left corner as the screen is facing down.
    • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
    • Set back cover aside.
  2. BLU Studio G Battery Replacement: 2 단계, 이미지 1/2 BLU Studio G Battery Replacement: 2 단계, 이미지 2/2
    • Locate the notch at the bottom of the battery for safe removal.
    • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
    • Set battery aside and insert new one .
결론
Christian Perez
회원 가입일: 04/11/17
515 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 360
