소개
Use this guide to fix a broken or cracked screen on the BLU Studio G. The replacement will require a near complete disassembly of the phone since the connections to the motherboard will have to be disengaged.
필요한 것
1 단계 Motherboard Prerequisite
주의: 1-8 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
Locate the two connector clamps on the motherboard.
Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
Turn the phone over after detaching the connectors that were attached to the motherboard
Carefully pry between the screen and the bevel with precision tweezers lifting slowly separating the screen.
Use of another thin tool will help support the lifting
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Can anyone tell me where I can buy a screen for a blu view 3
Thank you
mrcblake50@gmail.com
