소개
필요한 것
Remove the P2 screws.
Remove the SIM and SD cards, as well as the adapter.
Pull off the protective cover from the camera.
Remove the screws with a #00 Phillips screwdriver.
Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
Remove the microphone/speaker board assembly by pulling downward.
The battery has a small notch to facilitate removal, but the battery has been glued in place.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
Umm not sure what BLU Vivo 5 your giving these instructions for, my BLU Vivo 5 has no screws. Looks the same except for bottom speaker area, mine has type c and other wither side 2 slots one for mic one for speaker, no screws.
This guide is NOT for BLU Vivo 5. It's probably for the mini version. The BLU vivo 5 doesn't have screws at bottom...
