주요 콘텐츠로 건너뛰기
BLU Vivo 5 Mini Back Cover Replacement
필요한 것
  1. BLU Vivo 5 Mini Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 BLU Vivo 5 Mini Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 BLU Vivo 5 Mini Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
    • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
  2. BLU Vivo 5 Mini Back Cover Replacement: 2 단계, 이미지 1/3 BLU Vivo 5 Mini Back Cover Replacement: 2 단계, 이미지 2/3 BLU Vivo 5 Mini Back Cover Replacement: 2 단계, 이미지 3/3
    • Remove the top and bottom covers.
    • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
    • After freeing the edges gentle start peeling the covers off.
  3. BLU Vivo 5 Mini Back Cover Replacement: 3 단계, 이미지 1/3 BLU Vivo 5 Mini Back Cover Replacement: 3 단계, 이미지 2/3 BLU Vivo 5 Mini Back Cover Replacement: 3 단계, 이미지 3/3
    • Using a Phillips #000, remove all 10 screws found on the back of the phone.
    • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
    • The 4 on the top can be removed with the same screwdriver.
  4. BLU Vivo 5 Mini Back Cover Replacement: 4 단계, 이미지 1/3 BLU Vivo 5 Mini Back Cover Replacement: 4 단계, 이미지 2/3 BLU Vivo 5 Mini Back Cover Replacement: 4 단계, 이미지 3/3
    • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
    • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
    • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
결론
You can also use steps 1-4 for any other internal replacement.
다른 한 분이 해당 안내서를 완성하였습니다.
Kymari
회원 가입일: 10/09/18
710 평판
안내서 5개 작성하였습니다
Sam Houston State, Team S15-G6, Blackburne Fall 2018 Sam Houston State, Team S15-G6, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 432
