주요 콘텐츠로 건너뛰기
BLU Vivo 5 Mini Battery Replacement
필요한 것
  1. BLU Vivo 5 Mini Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
    • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
  2. BLU Vivo 5 Mini Battery Replacement: 2 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Battery Replacement: 2 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the top and bottom covers.
    • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
    • After freeing the edges gentle start peeling the covers off.
  3. BLU Vivo 5 Mini Battery Replacement: 3 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Battery Replacement: 3 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Using a Phillips #000, remove all 10 screws found on the back of the phone.
    • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
    • The 4 on the top can be removed with the same screwdriver.
  4. BLU Vivo 5 Mini Battery Replacement: 4 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Battery Replacement: 4 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
    • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
    • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
  5. BLU Vivo 5 Mini Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove the leftover screws using the PH000 screwdriver and release the bottom speaker holder piece.
  6. BLU Vivo 5 Mini Battery Replacement: 6 단계, 이미지 2개 중 1개 BLU Vivo 5 Mini Battery Replacement: 6 단계, 이미지 2개 중 2개
    • After fully removing the black speaker piece, the battery should be able to easily lift out with the aid of the suction cup or spudger. (If difficult, carefully use pick to ease battery out of device.)
결론
작성자
2다른 기여자 명과 함께
Kymari
회원 가입일: 10/09/18
725 평판
안내서 5개를 작성함
Sam Houston State, Team S15-G6, Blackburne Fall 2018 Sam Houston State, Team S15-G6, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G6
3 회원들
안내서 5개를 작성함
1가이드 댓글
Since are NO screws on my Blu Vivo 5, it looks like the only way to get to the battery is to remove the screen and then the 20 or so screws to get to the battery. The screen may break in the process but that’s the only way I see.
Éric R - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,056
